Config logicielle Clouzot
Message par clouzot » 02 févr. 2020, 09:35
Ohla sûrement pas meilleur que toi en guidage, j'ai essayé 2 fois dans ma vie (et ça a foiré lamentablement, ou quasi).
Docteur ès-Photomoches — D.U. de jeté de monture — Finaliste de la Course aux Sangliers
Filtres : ZWO UV-IR cut — IDAS LPS D2 — Optolong L-Enhance
Conditions Avex/Bortle : Magenta/8 (en ville) — Orange/5 (colline)
Message par clouzot » 06 févr. 2020, 10:55
Quick and dirty translation, sorry:
I wanted to be able to run, in parallel:
- a mount management software (CPWI). For those who don't have a Celestron mount, EQMOD would probably be a replacement
- a complete planetarium software (Stellarium), because CPWI is rather limited in this regard. CartesDuCiel, KStars and TheSkyX are other options.
- Sharpcap, with the constraint that it should be able to control the mount and do platesolving.
- PHD2, optional autoguiding
Hardware prerequisites
- a Windows PC (with at least a Corei3 CPU) running Windows 10, or a Mac running Bootcamp. 4 to 8GB of RAM
- a Celestron mount (AVX, Evolution, Nexstar SE, CGEM II, CGX...)
- a CMOS camera (or two, if autoguiding)
- a wild boar, for the thrill.
Software prerequisites
1 - the ASCOM platform in its latest version (6.4SP1 or newer).
2 - CPWI (current version is 2.2.3)
3 - Stellarium in its latest version 0.19.3 that allows controlling an ASCOM mount
4 - Sharpcap, of course
5 - Optionnally, PHD2 for guiding
Settings
Once the above sotfware has been installed, there are some configurations to be made...
We start with Stellarium, which we want to be synchronized with the mount (which, itself, is controlled by CPWI)
In Stellarium's settings, "plugin" tab, look for"Telescope Control". By default, this plugin is not loaded when Stellarium starts.
Click on the "load at startup" checkbox, then completely close Stellarium and relaunch it
Once this has been done, you'll be able to click on "Configuration" in this plugin. The below window will appear. There's a default telescope, already present.
Click on "configure", which will allow choosing the connection to the mount. In our case, ASCOM.
Scroll down to find where the mount is selected: the "select a telescope" button will allow choosing the correct ASCOM driver
One click, and the ASCOM Telescope Chooser appears. It gives the list of all mount drivers available. The one we want is CPWI
Select CPWI then click OK
Afterwards, launch CPWI and connect your mount (either via the handcontroller, the Celestron focuser, Wifi, it doesn't matter). Here, for the sake of the tutorial, I left a default alignement, as if the mount was pointing to Polaris.
Back to Stellarium, and in the "Telescope Control Plugin" window, click on "Connect".
Stellarium is now connected to CPWI, which means you can choose an object in CPWI, ask the mount to slew to it, and Stellarium will update as well.
This also works the other way: you can point something in Stellarium (look for a telescope button at the bottom right of the window) and CPWI will pass the goto instructions to the mount.
Of course, you can connect Sharpcap in parallel. The three software will then be able to control the mount. Sharpcap will then be able to platesolve and recenter the object.
PHD2 can also be connected by using the CPWI ASCOM driver
So we now have a complete setup for Celestron mounts, that allows:
- aligning your mount
- selecting the target in a fancy planetarium software
- livestacking
- autoguiding
[/notranslate]
Message par clouzot » 14 févr. 2020, 09:40
Et pour avoir testé récemment, une autre config potentielle pour les amateurs de Mac : avec Parallels (machine virtuelle, payant), il est possible d'installer un Windows sur le Mac et d'y accéder depuis macOS, sans redémarrage.
Il fut un temps où on ne pouvait pas faire fonctionner Sharpcap comme ça car il ne trouvait pas la caméra branchée en USB sur le Mac, ou bien refusait de la faire fonctionner.
Ce n'est plus le cas : j'ai fait tourner Sharpcap dans Parallels, et j'ai pu y connecter ma caméra en USB3 (20Mpix quand même), ma monture, le tout étant reconnu directement par Sharpcap et les autres logiciels (CPWI, ASICap...). La caméra donne le même framerate que si je la branchais sur un vrai PC, donc pas de souci de perfs.
Papylima
Message par Papylima » 14 févr. 2020, 10:47
Ah ! top cool...
Je vais essayer ça dès que je me serai un peu renfloué. Parce qu'après avoir craqué pour un C8 + un Night Owl, même d'occase, je suis un peu à sec... :cry:
Ça m'éviterait de redémarrer sans arrêt pour passer de MacOS à Windows et inversement.
Merci Clouzot :hand:
AVX
101 ED F 4,1 - Celestron C8 XLT
RdF Nightowl 0,4
ZWO ASI 224MC
Zone AVEX vert chez moi - bleu à 5km quand il n'y a pas trop de camping cars sur le parking :mrgreen:
Message par Petit Astro » 30 mai 2020, 16:51
Yop, bon je viens de suivre ton tuto et tout semble baigner (de jour avec juste la monture à vide, sans trépied, ni scope)
Mis les pilotes ascom, parametré cpwi, stelarium et sharpcap par une connection à la monture évolution en filaire via le hand contrôleur et l’usb du pc, j’ai fait ainsi car j‘ai parfois des déconnexions de wifi pendant la nuit qui m obligent à redémarrer la monture et ça m oblige derrière à refaire l’alignement 3 étoiles et ça c’est fatigant.
Seules les commandes sharpcap semblent saccadées, le mouvement n’est pas très propre, ça fait des a-coups, pour cpwi et stelarium nickel par contre.
Merci ;)
- C9.25 + Alt-Az Evolution + Table équatoriale
- ASI385MC
- Crayford UNSC2 V-Power
- Rdf : Celestron F/6.3 SCT - Kepler x0.5 - Meade F/3.3 SCT
- Filtre Astronomik UHC visuel - Polarisant rotatif Baader - UV/IR cut
Message par Lavinch31 » 01 juin 2020, 08:54
Je ne connaissait pas Parallels , je vais creuser car j'ai également un mac book pro... si cela peut m'éviter une revente a perte/frais sup° dans un pc :-?
Télescope: Dobson SW 305/1500 Flextube GoTo
Caméra: ZWO ASI 224 MC
Divers: EAF Advanced ZWO - ADC ZWO - RdF 1,25" TS Optics 0,5x - Barlow Televue 3x - Focal Extender ES 2x - Oculaires ES 82° 8.8 mm , 14 mm
Bortle 4 ( depuis mon jardin)
Message par clouzot » 14 juil. 2020, 17:59
Comme disait l'autre : "J'ai changé".
Changé de logiciel bien sûr, du moins quand je n'utilise pas CPWI faute de monture compatible. Auquel cas, je tourne alternativement avec deux logiciels de planétarium qui supportent le contrôle de monture :
- HNSKY, qui a un immense avantage : il est très, très léger, pas comme Stellarium (oui, je déteste ce logiciel). Même auteur que ASTAP
- Cartes du Ciel, presque aussi léger et quand même un peu plus joli qu'HNSKY. Lui offre une fonction classique mais fort utile : des listes d'observations, afin de préparer ses soirées bien au chaud.
Les deux savent récupérer les positions des comètes (quand il y en a). HNSKY offre l'avantage de lire à peu près n'importe quel catalogue, du plus classique au plus obscur, et d'inclure une liste redoutable d'astéroides (pour ceux que ça intéresse). Les deux se connectent sans autre forme de procès à la monture ASCOM. HNSKY sait également envoyer une commande ASCOM Sync, ce que ne sait pas faire CdC apparemment.
Message par bemo47 » 14 juil. 2020, 19:04
mais que sait faire Stellarium..... :D qui est effectivement un peu lourd.... :)
Sud-Ouest, TSOptics Newton 200x800 carbone, ASI533MC, guidage ASI224MC et TS 50x205, Focuser de PA, EQ6RPro, poste fixe automatisé
Message par clouzot » 14 juil. 2020, 19:42
...et pas qu'un peu d'ailleurs. HNSKY consomme à peu près 0.5% de mon quad-core i5, CdC 0.8%, et Stellarium...ben entre 7 à 10%, sans rien faire, avec 3 étoiles affichées.
Par contre, je me dédis, je me suis planté : CdC sait très bien faire un sync, c'était juste un peu planqué au fond du menu Telescope.
Message par bemo47 » 14 juil. 2020, 19:55
ça doit être l'ergonomie qui se paye, moi j'arrive pas à me faire à l'ergonomie de CDC ou HNSKY
Message par clouzot » 14 juil. 2020, 20:15
Bien sûr, il n'y a pas à tortiller, TSX est bien plus ergonomique. C'est son prix (et son modèle économique débile à base de droit d'entrée + location annuelle, sans parler des modules qu'il faut acheter en sus) qui m'arrête. Quant à CdC ou HNSKY, ils sont moches (surtout ce dernier) mais on se fait rapidement à leur fonctionnement. Sans parler de leur consommation fort réduite, qui est un critère prioritaire pour moi qui suis souvent en itinérant...
Message par bemo47 » 14 juil. 2020, 22:16
C'est pas faux :mrgreen:
Message par Steph » 15 juil. 2020, 00:02
J'ai testé les 2, c'est super léger, sollicitent très peu le CPU
Et les plus gourmands, TSX
Et N.I.N.A., si l'on peut le considérer comme un planétarium...ben y a un Sky Atlas, 35 % d'utilisation du CPU, mais la capture est activé et il exécute des séquences
Message par kawa » 15 juil. 2020, 00:09
mais que sait faire Stellarium..... qui est effectivement un peu lourd....
Ben ouais , et plus il en fait ,plus en en veut , plus on charge le baudet .
On peut le faire maigrir en ne chargeant pas tout ( il faut sauvegarder la config de démarrage 'soft')
Pas obligé , les satellites , les comètes périmées ,les astéroïdes .....
Pas obligé , toutes les infos sur les objets , les atmosphères , bref toutes les bricoles pour taper l'oeil
Pas obligé afficher des lignes ...et pas obligé non plus les photos :o
Apres le régime comme j'aime , un peu plus véloce , mais il a perdu son âme .
Moi je ne m'en sert que pour repérer les cibles et leur nom . Le pilotage est confié a un autre .
Bon il y a bien mieux , mais ........... ;)
Newton 150/750 PERL -Celestron C9.25 - AVX Goto - ASI 533 MC - Altair 183C PRO et 290 C - EQ3-2 Motorisée- Red 0.5 -3.3 -6.3
Message par clouzot » 15 juil. 2020, 00:21
Merci @Steph. Cette NINA, si elle n'était pas aussi exigeante, je prendrais bien rendez-vous. Le coup de l'atlas "à la Telescopius" est vraiment bien pensé (et l'assistant flats aussi d'ailleurs).
(le fond d'écran du Eagle me fait marrer à chaque fois. Je vois d'ici le gars à lunette de PrimaLuce nous expliquer avec force mouvements de mains combien quello systema è meraviglioso, te lo dico io. Perché è rosso)
(quand je me suis fait arrêter samedi dernier par la douane italienne avec mon Evoguide dans le coffre, c'était nettement moins meraviglioso. 20 minutes à expliquer en "frantalien" à quoi sert un télescope qui n'est même pas rouge, juste pour qu'il ne décide pas de tout démonter pour chercher je ne sais quoi). Première fois que je me fais stopper en 20 ans, pas compris, j'ai l'air honnête pourtant et j'avais même pas de faux Vuitton dans mon coffre)
@kawa j'ai bien essayé la version dégraissée en virant progressivement toutes les options, mais il bouffe quand même pas mal car il tape systématiquement sur la carte graphique pour tout, même simplifié à l'extrême, apparemment.
Message par Steph » 15 juil. 2020, 00:45
J'ai trouvé comment moins solliciter le cpu avec TSX, on peut soit baisser le taux de rafraîchissement de la position de tout les objets affichés (par défaut 30 fois par seconde), soit rajouter la commande "Sleep" qui met en standby ce rafraîchissement.
Sans sleep
Avec sleep...10% de gagné
